P0141 02 Honda Accord 2dr 4 cylinder
Old Nov 9, 2022 | 09:50 AM
Dannynicholas@mail.com's Avatar
Default P0141 02 Honda Accord 2dr 4 cylinder
It’s my downstream o2 sensor (after cat) I’ve replaced with oem sensor & attempted to reset CEL it pops back up almost immediately. I then checked the fuses no issues there. I then visually inspected the wiring (as best I could) that’s underneath near the front passenger wheel & also did from above in the engine bay. If I’m standing in front of the car it’s at the left rear near the wheel well. I do have a voltage meter but wanted some advice on testing the wiring. Also assuming that test comes back fine then it can only be a bad ECU ? Or can it still be a wiring (ground) problem ? I truly believe it’s a grounding issues myself. I’ve also read that it needs to be driven in order to “reset” the CEL but I don’t believe that to be true but that’s why I’m asking. Thanks in advance
a possible wiring diagram of the o2 sensor to the ecu would be helpful. I was going to rig it directly to the ecu & see if that fixes the issue.
Old Nov 10, 2022 | 05:23 PM
What are the wire colors at the harness for the O2 sensor?
reyoque
Mar 3, 2019 12:30 PM
RobinsonRicer
May 11, 2014 05:41 AM
ajvasquez
May 13, 2011 10:52 PM
dukasboy
Jan 1, 2011 11:41 AM
