tsx o2 CEL
Old May 10, 2014 | 08:33 AM
RobinsonRicer's Avatar
Question tsx o2 CEL
This is at my job where even the experienced mechanics are stumped..
05 TSX with a k24 comes in with a CEL. P2195 (o2 stuck lean) and a p0171 (system too lean).
I'm looking at the system with a snap on scanner and see
AFR 14.56
LTFT 19%
STFT 0%
HO2S1 0
HO2S1 HTR OFF
and the downstream sensor occasionally gets a reading but most of the time is dead and the car has definitely ran long enough for closed loop.
I tested the oxygen sensor disconnected from the harness. I get microvolt readings that vary with the engine rpm. The o2 sensor seems to be working perfectly.
But at the harness I'm getting no voltage or ground at the heater and the volts specified by the snap on for the sensor wires are out of spec.
Seems like a bad ECU or harness. But that's rare...
The other mechanic tried clearing the codes and every time they popped up 10 seconds after the car is restarted.
So anyone know if there is a common issue with the tsx/k24s?
And would the downstream sensor stop reading if the ECU sees that the upstream is bad?
Thanks
Old May 10, 2014 | 06:29 PM
holmesnmanny's Avatar
i would start with an exhaust leak test using seafoam and look for white smoke leaking out
Old May 10, 2014 | 06:33 PM
shipo's Avatar
Probably the only good application of Seafoam I've ever heard of.
Old May 10, 2014 | 08:29 PM
Thanks for the suggestion but I could not find one. The o2 sensor reads absolutely nothing at the ECU, even though its fully functioning. The computer would still show something even if there was an exhaust leak.
Old May 11, 2014 | 05:41 AM
lol totally agreed xD
lean = too much oxygen
ikaruga11
Feb 5, 2007 07:31 PM
adonisanemone
Dec 14, 2006 11:58 AM
dave118811
Mar 18, 2006 06:21 PM
Leonhartilly
Feb 3, 2006 01:15 AM
Tonyride
Jun 10, 2005 07:47 PM
