P0401 code & Injector identification for O ring
Old Nov 8, 2013 | 11:27 AM
bsdubois's Avatar
Default P0401 code & Injector identification for O ring
I am receiving an intermittent P0401 (insufficient EGR Flow) code. I plan to clean the intake manifold passages as described in Eric the Car Guy's youtube video. I plan to replace the "O" rings on the injectors and the gasket as they are reasonably priced and I don't want to have to redo the repair should the old part leak. I have one major problem. The injector "O" ring (on the end that inserts into the intake manifold) item 2 shows two different part numbers on Majestic Honda's online parts look up. I used my vin number and hoped it would give me only one choice. Evidently Honda used two different manufacturers of fuel injectors: NOK and OTSUKA. I looked on the injectors for markings and could not find any. Is there an easy way to determine which fuel injector type I have installed in my Accord?
The plan is to remove the entire fuel rail as a unit and not disturb the seals on the upper end of the injectors. I should only need the lower seals.
Thank you in advance for your assistance.
Old Nov 8, 2013 | 03:04 PM
Roader's Avatar
I only needed one O-ring when I did this job pulling the rail. The local auto parts store sold a Beck/Arnley kit that included lots of seals & O-rings including the one I needed. I'm guessing that the kit included O-rings for both injector types. It wasn't cheap, like $9 per injector, but I needed only one seal and it worked fine.
BTW, I don't think OBD2a is smart enough to sense that EGR ports are clogged so the ports probably aren't causing the CEL. The FSM's EGR diagnostic pages are very good.
Shag Wagon
Oct 23, 2010 10:12 PM
lgnaclo
May 18, 2010 12:07 PM
SignetSilverAccord
Nov 3, 2009 06:49 AM
boksh928
Oct 31, 2009 11:19 PM
Tippman7641
Nov 5, 2008 01:21 PM
