P0462 Code?
Old Jan 7, 2012 | 06:54 PM
CapptainCLUTCH's Avatar
Default P0462 Code?
I got a CEL last week (2005 Accord coupe LX 4cyl auto) but it ended up turning off after a few days. I checked the codes today (after the light turned off) and ended up with the following.
Vehicle VIN:
Vehicle Manufacturer: Honda
Vehicle Calibration ID:
Current Fault Log
P0139: O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
Pending Fault Log
ECU reports no pending faults
Historic Fault Log
ECU reports no historic faults
Other discovered fault codes
(possibly pending, current or manufacturer specific)
P0462: Fuel Level Sensor Circuit Low Input
End of report.
AKA- P0139 and P0462
I have the secondary o2 sensor on order to clear up the first code but I can't find any information on P0462. Anyone have any experience with it? It sounds isolated from the first code in my opinion but I've been wrong before... Thanks in advanced!
Old Jan 7, 2012 | 09:00 PM
P0462 likely means a short somewhere in fuel level sensor circuit. It could be faulty sensor, wiring, connector, or less likely a faulty ECM.
Check is to access the fuel sensor connector in the trunk, disconnect connector, turn ignition switch On, reset ECM w/ scanner, and see if code P0463 is set. This would indicate correctly that fuel level sensor circuit is open and indicate that fault must lie in the fuel level sensor, which should be replaced. If P0462 is set again, the short lies in wiring, connector, or ECM.
The above is a shortened diagnostic. The actual diagnostic is much more extensive. You may want to purchase your own shop manual from ebay seller automanualsource ($21.99), a good vendor.
Old Jan 7, 2012 | 09:21 PM
Excellent advice! I'll check it out this weekend. Thank you
Old Jan 17, 2012 | 12:20 AM
In case anyone comes across this same issue.... Replacing the ho2s cleared up both codes.
usmrocks
Nov 28, 2010 09:32 AM
tingjunkie
Sep 17, 2010 06:37 PM
will'i'am
Sep 16, 2010 01:19 PM
Stener75
Jul 25, 2010 08:21 PM
madsteez
Jan 18, 2009 07:43 PM
