P1491 Twice & Studdering/Shaking
99 Accord EX Coupe
P1491 fault code twice.
P1491 = P1491 EGR Valve Lift Insufficient Detected
I've changed the EGR Valve. I've cleaned both sides of the port on the throttle body side and the EGR Valve side. The throttle body side was completely clogged. I cleaned it as far down in as I could on both ends, but I haven't ran something like a coathangar all the way through. Is there something else I can clean or change to fix this?
As for the studdering or shaking that I mentioned in a previous post, there is Service Bulletin from the link that HondaDude posted under the DIY'er post. Great link, thanks. It stated that it was the torque converter causing this, and after reading this and driving the car I believe that it is the torque converter causing it.
Automatic Trans, Coolers, Torque Converter
1999 HONDA ACCORD
08/22/2000
TRANSMISSION BANGS IN REVERSE
08/22/2000
VIBRATION WHILE DRIVING AT LOW SPEEDS
03/02/2005
SAFETY RECALL: IGNITION KEY IS REMOVABLE WITH THE SHIFT LEVER OUT OF PARK
03/07/2005
SAFETY RECALL - IGNITION INTERLOCK SWITCH
12/08/2003
RECALL - IGNITION SWITCH EXCESSIVE WEAR PREVENTS INTERLOCK
Thanks again for your suggestions and help.
1999 HONDA ACCORD
08/22/2000
08/22/2000
03/02/2005
03/07/2005
12/08/2003
