Parking Brake Adjustment Help
Old Feb 28, 2009 | 12:21 AM
ramman05's Avatar
Smile Parking Brake Adjustment Help
I have a 1996 Accord LX with drum brakes. Just replaced drum brakes on rear of car but I need to adjust parking brake. Does anyone have any detailed info on how to this. I tryed using the search but found nothing.
Thanks
Old Feb 28, 2009 | 04:08 AM
IAMCANADIAN
check in the diy section and download the manuel for your car it should be some where in there.
Old Feb 28, 2009 | 11:17 AM
deserthonda's Avatar
since you just replaced rear shoes , first of all you got to adjust the rear shoes,, turn the little star adjuster downward to tighten the adjustment, do it a bit at a time ( 2-3) clicks , put the drum back on and spin it,, .. do this till you feel a very slight drag, than back the adjuster screw back ( upward ) 2-3 clicks ..
Once the shoes are properly adjusted, chk the clicks on the e-brake should be around 5-6 clicks ,, if more than that, there is an adjuster nut in the center rear of the center console ( 12mm) some models just pop out the rear ash tray or a cover in the console and you will see it ,, tighten the nut till you have 5-6 clicks,, then spin the rear drums to make sure that they still spin freely
Old Feb 28, 2009 | 08:30 PM
ramman05's Avatar
Thanks deserthonda for the info, did just as you said about adjusting the brake shoes now I need to adjust the E-brake.
Thanks Again
Old Feb 28, 2009 | 09:07 PM
Start car then press and release brake pedal several times. Stop engine. Put the back of the car on jack stands. Remove center console. Pull E-brake up one click. Tighten adjusting bolt until the rear brakes start to drag. Release parking brake and make sure that the rear brakes don't drag.
You can get this info from a pdf of a 94 shop manual from spoon honda link in the Online Manuals thread in the DIY section. It is pretty much identical to your 96. With a couple of minor exceptions (crank angle sensor is on the engine block not in the distributor, and your car is obd2). It is an invaluable reference.
Old Feb 28, 2009 | 11:20 PM
i just wrote a new thread in the DIY section ( 94-97 accords lots of info ) there is a link, click on it, click on main menu, click on brakes , on the left upper side ( 19-5) parking brake adjustment ,,,it has pictures and instructions very easy to follow
Leonkowal
Nov 27, 2013 06:34 AM
madadam
Oct 30, 2011 08:28 AM
2003 V6
Jul 16, 2008 08:02 AM
2003 V6
Jul 6, 2008 10:16 AM
foxracing31702
Apr 26, 2007 02:37 PM
