part name?
so im replacing a gasket on my air intake and i have no idea what the name of it is. its directly across from the throttle body if the makes any sense. its on the same thing just on the other side of it. its a little metal thing held in place by 3 maybe 4 10mm bolts, i cant remember. but it usually has 3 small hoses that connect to it by just being slide into place. i need to replace the gasket but i cant find the name of it anywhere and advance auto parts doesn't know what im talking about even after i showed them the old gasket.
Go to parts(dot)sonshonda(dot)com/default(dot)aspx, put in your model/year/trim, etc., click on Engine, then click on THROTTLE BODY. You'll see a list showing you what part #16 is called. I'm guessing it's a Honda dealer-only part. Print the list and take it with you to the dealer. They're famous for ripping off DIY'rs.
fourbanger
Aug 26, 2009 11:52 PM
nicolaselias
Mar 24, 2008 12:12 PM
