Parts needed for timing belt change
Old Nov 9, 2012 | 11:47 AM
jtimc7's Avatar
Default Parts needed for timing belt change
I'm going to change my timing belt on my 2000 Accord.
Are there any parts that I will need other than the following to do a thorough job?
-water pump
-tensioner
-timing belt
-secondary belt
-all front oil seals (3 seals & 1 gasket)
-thermostat
Thanks
Old Nov 9, 2012 | 02:22 PM
That is pretty much all of the parts you will need.
There is a video on the ericthecarguy site that goes over how to replace the timing belt for $10 and is worth the investment, IMO.
Old Nov 9, 2012 | 04:05 PM
accordfan's Avatar
recommend changing the valve cover gasket at the same time. good time to put spark plugs and external belts too.
Old Nov 9, 2012 | 04:39 PM
welland99's Avatar
Gosh, that sounds like a fairly big investment to replace all those parts.
Old Nov 10, 2012 | 01:08 AM
jtimc7's Avatar
Thanks guys!
I plan on using Genuine Honda parts.
Which of the online parts houses seems most reliable for Genuine Honda parts?
Old Nov 10, 2012 | 03:13 AM
holmesnmanny's Avatar
hondapartscheap if you're on the west coast and hondaautomotiveparts if you're on the east coast.
Old Nov 10, 2012 | 08:47 AM
accordfan's Avatar
Originally Posted by jtimc7
Thanks guys!
I've changed several timing & balance shaft belts on my Hondas over the years and always used parts from the local O'Reilly's auto parts store.
Lifetime warranty on the belts and never had a single issue. Much cheaper than the honda dealer.
DonnieVanDango
Jul 28, 2013 01:50 PM
KincaidChance
May 3, 2011 01:13 AM
Tony1M
Apr 1, 2007 05:42 PM
wayneboard2
Dec 8, 2006 11:56 PM
