passenger door light not coming on
Old Jul 29, 2011 | 05:34 PM
Haccord96W's Avatar
Default passenger door light not coming on
i changed the little bulb in there, but its still not working... the other door's light works when i open it, but not this one... how can i check if the contacts are good? resistance or what?
Old Jul 29, 2011 | 06:33 PM
Peli's Avatar
What year is your car? I'm having the same issue with mine.
Old Jul 29, 2011 | 08:15 PM
Haccord96W's Avatar
THE EXACT SAME model and specs as yours but mines a 96
Old Jul 29, 2011 | 08:20 PM
bigpat's Avatar
Almost A Senior Member
You could check the voltage at the socket with a 12v test light...If none is present, then check the switch mounted at the front of the door jamb. Also, give the light socket a short blast of wd40 to clean the contacts, wipe out the excess and re-install the bulb. I had an old Honda 750 motorcycle that needed that treatment on the contacts inside the horn button...Worked like magic...
Old Aug 5, 2011 | 09:55 AM
cb7sk8rdude's Avatar
If you take the door panel off check to see if the wires are all hooked up
MSC71
Nov 23, 2019 05:28 PM
Winston Hart
Sep 7, 2013 12:32 PM
N1Accord
Mar 24, 2011 11:27 AM
RS250 Chester
Jan 19, 2010 11:06 AM
JD911
Oct 19, 2009 09:18 AM
