Passenger and rear windows not working
Old Dec 12, 2013 | 06:42 PM
  #31
i4getlots's Avatar
Lol, my mistake. I initially thought you meant you only had a valet key.
Ok so in the link you gave me my key looks like the 03-04 key.. Hopefully that helps clear any confusion :-) so back to my original question. Can i reprogram it my self or do i have to go to the dealer? Im almost tempted to call the dealer and ask
Thanks for all the information! I have been without remote locking for three months now... I really miss it !
Old Dec 12, 2013 | 06:46 PM
  #32
You can do it yourself and have the functionality back today.
Old Dec 12, 2013 | 07:42 PM
  #33
i4getlots's Avatar
And the programming process should work? If not im coming back to complain :-)
Old Dec 12, 2013 | 07:51 PM
  #34
i4getlots's Avatar
It worked! Thanks for all the help! I had to do it a few times because i didnt take the key out after it programmed itself..
Old May 28, 2014 | 10:24 AM
  #35
myhumblecar's Avatar
There is a test you can do to see if it is the door multiplex control unit. I take no credit for it, it is by a Honda tech, who goes by the username justinsbg on another forum.
At the 23-P connector for the door multiplex control unit, attach a wire to cavity 3 (where the WHT/GRN wire is), with the connector plugged back in, turn the ignition to ON. Ground the WHT/GRN wire to body and try to operate the other three windows. If they work with ground to the WHT/GRN wire; but, doesn't when it is not grounded, then it is a faulty door multiplex control unit.
I may be a year late but I just wanna thank you so much for this post, saved me so much time from trying to diagnose this issue.
Old May 28, 2014 | 11:59 AM
  #36
Good to hear. You're welcome.
Old May 28, 2014 | 08:58 PM
  #37
bryyce62's Avatar
Hello,
I have nearly the same problem as the others here. An 05 coupe, passenger window will not budge. I get a click from the drivers door control, that's it. Tried to short the white/green wire to ground and still no help.
Bought a new main control, still nothing.
Any help would be appreciated.
Old May 28, 2014 | 09:24 PM
  #38
Originally Posted by bryyce62
Hello,
See this thread:
https://www.hondaaccordforum.com/for...99/#post346134
Old Nov 20, 2014 | 01:26 PM
  #39
BluCrossGun's Avatar
I know this is a litle late but I have the oposite problem.
My passenger right rear window is making the clicking and not coming up.
I have the door panel off and replaced the regulator with the motor but it still makes the clicking noise when I push the button to make it come up.
Does anyone hae any ideas?
Old Nov 20, 2014 | 03:38 PM
  #40
1. What year is your car?
2. Does it do the same thing from both the master switch and the passenger right rear switch?
3. Does the window work at all with the switches (e.g., goes down)?
