PLEASE HELP!!! I'm desperate!!!
Old Apr 9, 2007 | 11:07 PM
suprarx7nut's Avatar
Default PLEASE HELP!!! I'm desperate!!!
My 91 Accord is fine until the engine warms up. Then when the engine speed comes down into idle,it drops to about 100. Sometimes the car stalls. After it falls to 100 RPM, it slowly rises back up to its normal idle(700-800) RPM.
It has stalled while I'm brakingafter I take it out of gear.
I took it in a month ago and they said my timing was just off. This fixed the problem for a while, but now its back!
Why would my ignition timing be off again?!
NOT SAFE!!!!
PLEASE HELP!!!!!!
I work tomorrow afternoon so I have until then to try to fix this dangerous problem.
Old Apr 10, 2007 | 11:09 AM
deserthonda's Avatar
Default RE: PLEASE HELP!!! I'm desperate!!!
I would start by cleaning out the throttle body..... any codes ??
If the timing belt is loose it could jump .... chk timing to make sure it is still ok,
Old Apr 10, 2007 | 05:09 PM
Timing belt was just replaced and I don't get any codes. I do occasionally get a speed sensor code and my speedo will cut out, but that seems to happen completely independently.
Old Apr 10, 2007 | 05:19 PM
Shadow1992's Avatar
have you checked and adjusted your throttle cable? if it's too slack it could be allowing your throttle body to completely close.
Old Apr 10, 2007 | 05:58 PM
How could I adjust that? I'll go look at it now, but I won't really know exactly what I'm doing.
Thanks for the help guys, I really appreciate your help. I'm a working college student and it sure beats paying a mechanic 100/hr to try to find problems in my car that MIGHT fix it.
Old Apr 10, 2007 | 06:12 PM
Holy crap!
I just moved the cable further away from the throttle(tightened it to remove slack) and it worked!
It's fixed for now, i guess.
I'll let you guys know if the problem returns.
THANK YOU SHADOW!!!!
Old Apr 10, 2007 | 08:31 PM
hondadude's Avatar
ORIGINAL: Shadow1992
Ooops, there is supposed to be a littleslack in the throttle cable. tightening the throttle cable is not the way to adjust idle speed.
The OP needs to check the IAC to be sure it is functioning.
Old Apr 11, 2007 | 02:19 AM
Ya, its still acting funny. It doesn't stall now, but its not quite right.
How do I check the IAC? I can't find it in my Chilton's manual.
pmb1903
Aug 3, 2014 01:21 PM
americanguy
Apr 12, 2012 08:42 PM
drummer1279
Aug 17, 2007 09:57 AM
darkside099
Jun 10, 2007 12:01 AM
hawaiian5
Dec 6, 2006 03:41 AM
