Please help me!
Old May 23, 2012 | 01:14 PM
AccordCoupeFreak's Avatar
Default Please help me!
96 accord cpe ex. When driving car will accelerate to 3000 rpm. Put it in neutral while moving and it stays at 3000 rpm. When stopped it goes back down to normal idle after a few seconds. Quits doing this after a bit of driving but will start again if I restart the car, full warm or cold. Speed sensor issue? Please help, im goin insane lol
Old May 23, 2012 | 06:28 PM
Is the engine actually at 3000 rpm, or is the gauge showing 3000 rpm?
Old May 23, 2012 | 07:21 PM
Yes. Until I come to a complete stop.
Old May 23, 2012 | 07:26 PM
the engine actually revs to three grand
Old May 23, 2012 | 07:32 PM
Me, I'd start with cleaning and adjust the IAC and FITV. Check the "Common DIY Threads" sticky at the top of this section......
Old May 23, 2012 | 07:51 PM
Along the same lines, I would clean the inside of the throttle body and both sides of the throttle plate with some throttle body cleaner.
Old May 24, 2012 | 09:02 PM
Thanx guys ill try that n see. I did get a tps code a while back and I put a new sensor in and cleaned the throttle body like new. Ill see n let u know.
@ PA..... Im in zelienople lol
Old May 24, 2012 | 10:58 PM
If this problem started happening right after the TPS installation, then you may not have gotten the sensor in properly. There is a slot in the sensor that fits on to the metal pivot on the throttle plate that you need to line up.
Old May 25, 2012 | 06:09 PM
It worked fine for a while. I adjusted it and it seemed to make a bit of difference so I think I got it all figured out. Thnx again!
esan805
Mar 29, 2012 02:33 PM
art vandelay
Aug 2, 2010 09:29 AM
mamtsberg
Mar 17, 2010 09:15 PM
BIGWILBO
Apr 5, 2008 07:57 PM
ryan ortego
May 19, 2005 06:06 PM
