Please HELP!!! My gauge is not working.
Old Jun 6, 2009 | 10:17 PM
zann121's Avatar
Default Please HELP!!! My gauge is not working.
Hi,
I was changing the bulb on my clock because i couldnt see the time at night. while i was replacing the little tiny bulb i had a short circuit and i saw a little spark. I usually see all the lights turn on right before u start the engine. but instead of all the lights turning on, I only see a red battery light turn on now. but it goes out after i start the engine. And now my speedometer, tachometer, odometer and my temperature doesn't want to work but my fuel gauge works. and also the first option on my wiper setting doesnt work but the other two works. I dont know why this is happening. Please help me. I dont know what speed i am going on so i end up going really slow on roads and freeways so i dont get pulled over. Please get to me as soon as possible.
THANK YOU VERY MUCH
P.S: I have an 1998 Honda Accord 4CYL SEDAN.
Old Jun 6, 2009 | 11:52 PM
Fuse's Avatar
Look at all your fuses under hood and under dash one is blown........
Old Jun 6, 2009 | 11:55 PM
zann121's Avatar
i checked, which fuse runs the cluster?
Old Jun 7, 2009 | 12:04 AM
Fuse's Avatar
Don’t know? Did you look at the fuse label should say gauges or some thing. Did you check the under hood and under dash fuse boxes?
It is probably a under dash fuse I think the 98s had a passenger and driver under dash fuse box.
Old Jun 7, 2009 | 06:36 AM
zann121's Avatar
i checked all 3 fuse boxes. i just cant seem to find which fuse is burned. this is really annoying me. its stopped working foro 3 days already
Old Jun 16, 2009 | 03:39 PM
Goldie007's Avatar
i think there might be a fuse between the cables that hook up to your gauges and to the ECU....but im not sure...
esan805
Mar 29, 2012 02:33 PM
wrencredle
Mar 5, 2012 07:57 AM
vikkyhonda
Feb 1, 2012 06:34 PM
pirulino23
Nov 10, 2010 06:18 PM
stevelaker
Jan 15, 2008 05:38 PM
