Plug seal won't come off
Hello Accord experts,
I'm having a hard time removing these plug seals on the valve cover. They seemed to have hardened over time and seemed to be permanently glued in there or something...
Any suggestions? Thank you!
yes, pry on them slowly. Also when you go for the gromets on the valve cover bolts-looks like a v-tec....place a piece of hose around the threads of the vc bolts....lube the hose and push the new seals thru the hose and past the hard/blunt stop on the bolts.
Those seals have a metal reinforcement on the outside edge. To avoid any possibility of scratching the valve cover sealing surface, I used a screwdriver to push the outside edge of the seal towards the center of the circle. Once is was bent inward, I used a pair of needle-nose pliers to pull out the seal.
ZMan3000
May 15, 2008 03:10 PM
