Strange Spark Plug Seal
Old Jul 26, 2006 | 01:22 AM
brave_mhy's Avatar
Default Strange Spark Plug Seal
Adjusted the valve lash last week (Many thanks to the valuable advise on how to rotate the crankshaft).
It was really a hard job to rotate the crankshaft from below due to the limited room there.
Now, I am puzzled by a new finding and deadly need input from the pro. who has probably seen this
before in the garage. To make it simple, I got a valve cover set to change the spark plug tube seal to
fix up the leakage in the spark plug area.
On the box it says:
Gasket Set Includes:
Valve Cover (1)
Spark Plug Seal (4)
Spark Plug Tube Seal (4)
Valve Cover Grommet (4)
I opened the box and found everything I needed for the job except the "O" ring shaped "Spark Plug Seal".
Does anyone have a clue about what these guys are? I checked a million times on the valve cover, spark
plug housing, etc., and could not find a place for them!
Based on my understanding, the spark plug tube seals are the right seals for the spark plugs. Why there
is another set of so called "Spark Plug Seal" in the box as well but could not fit anywhere on my 95' Accord
LX, F22B2 2.2L SOHC, Auto
Why don't I call the manufacturer and check out? I bet the pros of this forum know a lot more than they do.
Thanks
Old Jul 26, 2006 | 01:46 AM
Default RE: Strange Spark Plug Seal
#19, they go underneath the cam caps. Hang onto them, because someday you may need them.
Most likely the upper seals that you replaced, will fix the leak. If not, you'll have to remove the rockers & all that stuff to get to those seals.
Old Jul 27, 2006 | 05:04 PM
brave_mhy's Avatar
Once again, JimBlack, Appreciate your prompt help, and the picture you posted
is much detailed, very helpful!
Thanks!
Old Jul 28, 2006 | 04:40 PM
sir_nasty's Avatar
ritous picture post dude! gotta love electronic manuals!
Old Jul 29, 2006 | 12:01 AM
Actually it came from Majestic Honda (hondaautomotiveparts.com) & I bet it's ultimately from Honda's electronic parts catalog. Those pictures are really nice for pointing out components on the car.
But I should have warned you Brave... If you find you need to replace those seals, make sure you get a repair manual or at least post back here. The bolting sequence & tightening torque should be important for those cam caps. Don't just wing it...
Old Jul 29, 2006 | 02:36 AM
deserthonda's Avatar
there is a step by step write up on our DIY section on HOW TO replaace upper and lower seals
https://www.hondaaccordforum.com/OIL...m_16994/tm.htm
Nate McIntyre
Mar 2, 2013 06:24 PM
RussR
May 21, 2011 03:01 PM
offroadTRD
Jul 3, 2009 06:38 AM
tlhfirelion
Mar 2, 2008 09:57 PM
