popping/clicking when power applied
Old Nov 1, 2012 | 08:04 PM
Seth Mckiness's Avatar
Default popping/clicking when power applied
I have a 1997 Accord EX Coupe w/ 5 sp. when power is applied after letting clutch out from a roll or a stop there is small pop or click from the drivers side front end. CVJs make noise very occasionally... How worried should i be. I have one day off from work before going on a road trip. I just backed up in both directions and couldn;t get any clicking from torn boots, but occasionally get it at low speed at full lock. My understanding was this is the early signs, and not a fix right now issue. Am I horribly mistaken?
Old Nov 1, 2012 | 08:08 PM
Hamster108's Avatar
I have seen broken axles last as much as 30k miles. Stay away from potholes and you will be ok.
Old Nov 1, 2012 | 08:21 PM
Awesome, Just wanted someone elses opinion. Thanks for quick reply, will keep forum posted.
Old Nov 2, 2012 | 05:14 PM
ok, bought new drive shafts cause i couldn't sleep, and now i can't get them to go in, any ideas? they start but the ring keeps them from inserting. running out of daylight and stressing....
Old Nov 2, 2012 | 06:03 PM
Here is a good video on how to do this:
Make sure you line up the new cv joint to make sure it is the same size and splines as the original.
Old Nov 2, 2012 | 06:08 PM
just had to give them a light tap tap, all better, thanks for quick response though :-). needed a second set of hands to hold stuff out of the way.
Hybridman05
Aug 20, 2009 05:23 PM
newheadache
Mar 18, 2008 09:31 AM
00AccordLX5spd
Mar 22, 2007 06:36 PM
rjp
Sep 1, 2006 04:36 AM
lloydw88
Jul 6, 2006 11:41 PM
