Possible VTEC problem. Not Really sure.
Old Jan 8, 2009 | 01:49 AM
gonnatell1
Default Possible VTEC problem. Not Really sure.
[hr]
Hey, im new here and i have a problem with my car. I dont know much about Hondas so im hoping to get some help. Its a 1998 4dr Accord with a 2.3 Liter VTec SOHC automatic trans. Just 2 days ago i changed out both gaskets on the Vtec solenoid because they were both leaking oil. I got the gasket that sits between the head and solenoid at the dealer but they told me the smaller one on the spool valve is not produced anywhere. So instead, i used black rtv to seal it. I applied the rtv and let it sit for about a day. I put the solenoid back on and changed my oil with a new filter and put in the correct amount of oil. I drove it all day but it acts funny when i push it just a bit hard. It starts hesitating or it seems like its bouncing off a rev limiter at about 4000 RPM. I posted the video on youtube so yall can see. The check engine light is from an egr valve and the motor is all stock. I posted this question on another honda forum but no one responded. Just looking for some help.[/align][/align]http://www.youtube.com/watch?v=TTX22XXUDss[/align][/align][/align][/align]
Old Jan 8, 2009 | 11:07 AM
Default RE: Possible VTEC problem. Not Really sure.
Does it still leak?
Is the EGR the only error code stored now?
So the gasket you cant get is between the solenoid & the spool valve? The triangle flange? You may be able to get that by looking for the corresponding piece from an Acura Integra GSR.
Old Jan 8, 2009 | 03:19 PM
hondadude's Avatar
Clean the EGR passage and reset the ECU.
The engine will have a rev limit running with a code store in the ECU.
It is running in 'Default' mode; fixed parameters.
[IMG]local://upfiles/5417/BC4146ED08A24BC69A9ED90AE8523729.gif[/IMG]
white_ex94
Mar 9, 2010 12:19 AM
96FiveSpeed
Feb 7, 2010 02:09 PM
patcal
Dec 11, 2006 02:09 PM
GOTTI
May 15, 2006 11:09 PM
dude9571
Feb 12, 2006 07:32 PM
