possibly bent anti-sway bar
Old Jun 21, 2009 | 04:14 PM
goin to town's Avatar
Default possibly bent anti-sway bar
I have a 1993 Honda Accord LX, 5-speed, 4 door. When I got it I found that the sway bar links were completely dry rotted. When I replaced them I had a tough time getting it back together. I loosened the sway bar mounts to try to get the links to line up with the lower control arms and then broke one of the bolts off for the mounts. Fixed that, got it back together and drove it a while. Now I'm putting it back together after replacing the rotors, wheel bearings, shocks and coil springs. I sand blasted the sway bar and painted it.
I'm wondering if the sway bar might have been bent at some time like from when the links were rotted or from the previous owner bottoming out on something. The ends of the sway bar don't seem to line up with both lower control arms at the same time. Other than buying a new one I have no idea how to figure out if there is something wrong here. Any suggestions?
Old Jun 21, 2009 | 04:28 PM
I found on a 90Ex I had to loosely connect both sides w/ the guide bushings released from keepers, and then install keeper for guide bushings, and tighten end nuts.
Old Jun 21, 2009 | 04:47 PM
When my car is jacked up, the sway bar will not line up properly.
I would just put the tire back on and lower the car until things line up. Then you can tighten that bolt.
Old Jun 21, 2009 | 09:48 PM
Anti-sway bar should not align when one side of car is lifted. You must lift from both sides or lift from the center lift point and support both sides for safety.
Old Jul 7, 2009 | 04:23 PM
Default thanks
Thanks for the help. This went together with no problems. I don't know why I had so much trouble a few years ago. Maybe I'm just a better mechanic now. Having this forum helps a lot.
The sandblasted and rustoleum-green sway bar and lower control arms look pretty good under my old Honda.
rob3201
Jan 19, 2014 01:09 PM
xlino
May 10, 2013 01:56 AM
honda2K
Mar 21, 2010 12:05 AM
botaine
Mar 20, 2008 09:28 PM
otto
Jan 20, 2008 08:47 AM
