Potentially buying a 1999 Accord-please advise
Old Feb 25, 2015 | 06:19 AM
  #21
shipo's Avatar
Please understand I'm not saying a Gen 6 Accord EX with the V6 will be as cheap/easy to maintain as say a similar vintage Civic or Corolla with a 5-Speed manual, crank windows, and conventional HVAC; what I am trying to say is that for a nice mid-sized V6 sedan, the Accord will be on par (or better) compared to pretty much any other car of that ilk which is 15 years old and has well over 100,000 miles on the clock.
Old Feb 25, 2015 | 03:58 PM
  #22
M-train's Avatar
Originally Posted by shipo
Too funny, people don't change the filter because the filter doesn't need to be changed for the life of the vehicle. If at some point the filter clogs, it's because the rest of the transmission is failing, not the other way around.
WRONG. I have ran a transmission shop before so I do know what I'm talking about.
Anything like brakes pads, or clutches wear in normal use. The filter catches all of that debris, otherwise why even put a filter in a transmission.
So the filter starts getting clogged up with gunk, which causes a decrease in the transmissions fluid ability to circulate, which causes heat buildup, which causes the clutches/steels to wear even more.
I've also been building Ford transmissions for the local drag racers here on/off for about 30 years, and I can tell you that HEAT is the number one killer of transmissions. [lack of proper size cooler, or clogged filter, or both].
I won't go to the mat on stuff I don't know about, but this stuff I do know.
In fact I have just rebuilt a Honda transmission, and was really on the fence just to leave out the factory filter [as there wasn't one in my rebuilt kit] since I was also installing an external filter.
Old Feb 25, 2015 | 05:11 PM
  #23
shipo's Avatar
While it is true clutch material does get trapped in the filter, as do small wear metals, the filter is easily large enough to deal with hundreds of thousands of miles of particulate.
I won't argue the issue about heat, as I agree that is the biggest issue for automatic transmissions; that said, I will certainly argue flow through the filter is not a contributing factor in excess heat.
valvelash
Jan 17, 2013 08:06 PM
stout88
May 30, 2011 01:43 AM
xaznxeclipsex
Sep 13, 2007 07:54 AM
HondaAccordFan
Sep 11, 2007 04:57 PM
sir_nasty
Dec 6, 2006 01:16 PM
