Power door lock problem - 2011 Accord
Old Dec 31, 2014 | 12:41 PM
TCG1975's Avatar
Default Power door lock problem - 2011 Accord
My 2011 Accord EX sedan has developed an annoying problem. After initial start-up, my power door locks are set to automatically lock when the car reaches a certain speed, which I believe is 10 mph. However, over the past few weeks, the car has developed an intermittent problem. The locks will try to lock, even though they are already locked, when I accelerate from a stop and reach that 10 mph threshold. This happens at every intersection with a stop sign or stoplight, as well as in bumper-to-bumper traffic.
Another interesting event that I've noticed, is this usually happens when I try to lock the car from the outside, and the key fob will not arm the alarm by honking the horn. I can hear the locks being locked from the outside, but the horn will not honk with the 2nd press of the "lock" button on the fob, as it it supposed to do. Again, this is also an intermittent problem.
Does anyone have any insight as to what could be happening? I searched the forums and didn't find any posts explaining the same problem I'm having. Thanks in advance for any input!
Old Dec 31, 2014 | 02:55 PM
Since your security system is not always arming normally (e.g., horn or lights blink), it may indicate an intermittent issue with either a door switch or door lock actuator. It may be causing what you've been experiencing (i.e., doors trying to re-lock and security system).
HateThisHonda
Sep 19, 2013 09:45 AM
Doublel
Mar 11, 2013 07:57 AM
wahlyz
Dec 1, 2007 11:57 AM
isuboy
May 2, 2006 01:14 PM
