Power keeps shutting off for a second randomly
Old Aug 25, 2009 | 10:15 AM
doat's Avatar
Default Power keeps shutting off for a second randomly
I was driving to my bank this morning and while i was driving the electrics just shut off for a second randomly throughout the trip and when i was in my neighborhood on the way home i accidentally flashed my headlights and the car shutoff. I tried starting it but nothing happened, i tried taking the key out and putting it back in to start and again nothing happened until a minute later i started the car and went home. Could this be caused by my battery or is the alternator not charging it? I have a 98 accord LX automatic, i will check the terminals and clean them.
Old Aug 25, 2009 | 10:55 AM
mcnoople's Avatar
Just a guess, I would try the ignition switch. Does it act up if you wiggle the keys?
Old Aug 25, 2009 | 11:45 AM
deserthonda's Avatar
i would have to guess ign switch as well..........there is a recall on that, ever had it done??call the dealer, give them the VIN # and have them check if recall has been done
Old Aug 25, 2009 | 12:46 PM
Kawi9
I am having a very similar problem. I went to ahm-ownerlink.com and it says the recall on my ignition switch has been fixed but the ign interlock wasnt. When I turn the car on and move the key around everything runs fine.
Old Aug 25, 2009 | 01:31 PM
doat's Avatar
I will have to see if i can do the recall i figured it was ignition related or the negative terminal on my battery was loose. Thank you all very much for the speedy response. The recall date was may 16, 2002 would they still cover it if i do it now?
Old Aug 25, 2009 | 01:58 PM
mcnoople's Avatar
Yes, both recalls should still be covered. The interlock recall is just to prevent you from taking the key out of the ignition with the car in gear. It doesn't cause any problems with drivability.
Rotate the key towards the off position very very slowly. If you barely have to move the key before the car is turned off then it is likely your problem.
Old Aug 25, 2009 | 03:00 PM
doat's Avatar
Thanks mcnoople i will try it now.
Well i drove the car to walmart and it was driving normally, didn't shut off or turn the radio off or anything.
Old Aug 25, 2009 | 08:15 PM
Kawi9
Gonna replace the ignition switch tomorrow. Lets see how it goes. Thanks for all the help.
akevinjames
Apr 5, 2014 08:41 AM
iDriftYou
Apr 7, 2009 07:02 AM
88bluesi
Jul 6, 2008 05:36 PM
dave
Oct 25, 2006 03:33 PM
illu5ionz
Jun 17, 2006 04:52 AM
