power lock issue...
Old Dec 6, 2007 | 11:03 PM
OfDivineNature
Default power lock issue...
n
Old Dec 6, 2007 | 11:25 PM
nafango2's Avatar
Default RE: power lock issue...
As far as the light is concerned, try shorting the blue "service connector" under the glove box, then turning the key to "ON" and counting the number of times D4 flashes. That will tell you the error code.
and the power door locks, check all the fuses for one. there is one fuse box under the hood and one down by the pedals on the inside. check EVERY fuse, even if it doesnt sound like it has anything to do with power door locks. Missing a fuse can cause wierd stuff to happen to your car, no matter what the fuse has to do with.
Old Dec 7, 2007 | 09:20 AM
00AccordLX5spd's Avatar
Registered User
With the key off, set the wiper speed switch to the middle position. Crank car. See if windows work.
Old Dec 7, 2007 | 10:25 PM
OfDivineNature
ORIGINAL: 00AccordLX5spd
not to be rude, but umm what exactly would i need to do that for? my windows still work fine. i'm just going to assume that it was a misread. thanks anyways though!
HateThisHonda
Sep 19, 2013 09:45 AM
StrikingAccord
Jul 28, 2009 08:59 AM
keven2002
May 16, 2009 12:28 PM
Raptors
Sep 15, 2008 09:43 AM
