Power locks won't work after handle replacement
Old Mar 22, 2014 | 08:56 PM
mikebstone's Avatar
Default Power locks won't work after handle replacement
2000 Honda Accord EX-V6.
I replaced the rear driver door exterior handle today. After I replaced it with an OEM handle, I put everything back together and it all went smoothly. The door opened and closed from the outside and inside just dandy. I closed the door and was ready to call it a successful DIY until I tried locking the doors with the REMOTE. Nothing. The REMOTE power locks will unlock and the trunk will open, but they won't lock. The power lock SWITCH will lock/unlock the doors on the driver-side and passenger-side no problem.
Odd.
Any possible solutions you could throw at me would be great. To recap:
Remote will unlock and open the trunk, but NOT lock.
Power lock switch on driver/passenger will lock and unlock.
Old Mar 22, 2014 | 09:35 PM
1. First try resetting the multiplex system. Turn the intermittent wiper ring (on the wiper switch) to its mid-position, then turn the ignition switch to ON and OFF.
2. If resetting the multiplex system doesn't resolve the issue, then try reprogramming the remotes. See page 8 of the following service bulletin:
http://www.tegger.com/hondafaq/misc/98-011.pdf
Old Apr 1, 2014 | 08:03 PM
mikebstone's Avatar
I was at a buddy's place when I replaced the handle. When I got home the doors on the remote locked. Perhaps I had a door that was not closed all the way? Either way, issue is resolved. Thank you for the speedy reply.
Jcaleno
Jun 10, 2012 09:08 PM
trex
May 22, 2012 08:57 PM
ezekielguy86
Oct 16, 2009 11:03 PM
MALSR
May 30, 2009 03:33 AM
rtijerina
Jul 25, 2006 01:25 AM
