power steering fluid leaking
Old Mar 23, 2011 | 09:19 PM
jre3425's Avatar
Default power steering fluid leaking
I have to add power steering fluid every time I fill up with gas. Not quite empty, but have to about 3/4 bottle. A mechanic told me that I need to have the "power steering pressure switch" replaced. Does that sound like a legit diagnosis?
I have not been able to find a replacement part for power steering pressure switch. can I buy just the switch or do I need to buy an assembly that includes the switch?
Thanks,
James
1990 Accord EX
Old Mar 24, 2011 | 07:20 AM
PS pressure switch is #33 on this picture. Follow the high-pressure hose from the PS pump.
If you're not sure of his diagnosis, then follow the hose & find the PS pressure switch.
See for yourself whether it's leaking? If not, then you have to FIND the leak first before you can figure out how to fix it.
62maxx
Oct 18, 2015 08:20 AM
nyaccodguy
Mar 17, 2015 06:38 PM
jsprice2
Apr 7, 2013 08:33 PM
95_Honda_Accord_Ex_Sedan
Feb 17, 2013 08:28 PM
skytech76
Jul 12, 2007 06:45 PM
