Power steering fluid was leaking through bolt, need urgent help.(Only transportation)
Old Feb 17, 2013 | 08:28 PM
First, try the easy thing...
Remove the OTHER bolt & take off the hose. Now, there might just be enough of the broken bolt to grab with needlenose pliers. Or use a centerpunch to hit it off-center to drive it counterclockwise to loosen it.
If that doesn't work, you haven't spent any money nor spent too much wasted time trying.
Either way (new pump or not) you have to remember that the O-ring seals just by being there. If it leaks, overtightening the bolts will DO NOTHING to improve it.
62maxx
Oct 18, 2015 08:20 AM
nyaccodguy
Mar 17, 2015 06:38 PM
rics06
Jun 12, 2013 07:11 AM
jsprice2
Apr 7, 2013 08:33 PM
jre3425
Mar 24, 2011 07:20 AM
