Power Stering resevoir
Old Mar 11, 2006 | 04:00 PM
Skeete32
Default Power Stering resevoir
Hi I need help finding the power steering resivoir. I had an automatic but now I've Become a real driver and can now drive stick. The problem is where is the Resivoir on the 91 manual transmission Accord. I feel so dumb. Please help!
Old Mar 11, 2006 | 05:40 PM
lightshow's Avatar
Default RE: Power Stering resevoir
why do you need to know where the reservior is? you dont want to mess with that thing, you put the wrong fluid in it, you may need thousands of dollars in repairs. get back to me if you need to fill it i can help
Old Mar 11, 2006 | 11:42 PM
Skeete32
I ment that I need to top up the fluid, because I'm hearing a sound coming from the front end when I'm turning sometimes. It sound like my stomach when im hungry.
Old Mar 12, 2006 | 12:17 AM
marbro's Avatar
........ i doubt its the power steering being low thats causing that sound. And if its low you might have a leak somewhere.... but eitherway its just a matter of following the lines off the power steering housing
Old Mar 12, 2006 | 02:18 AM
mbo1985's Avatar
hahah my dodge truck cries because it leakes power steering fluid so fast... it serisouly makes an "OWWW" sound as you turn. If you suspect the power steering fluid is dangerously low, it is on the driver's side up front with a little red cap on it. Should be near your washer fluid. Make sure you use honda power steering fluid. and don't over fill!
A side note, my power steering leaked pretty bad in my accord. I noticed that there was a line that had a clamp on it near the motor and it was loose (was under the car). A few cranks tighter, and no more leak. If you're having a serious leak, check the easy stuff first.
Old Mar 13, 2006 | 02:09 PM
sir_nasty's Avatar
Just out of curiousity what kind of sound is it? is it a clicking sound by chance just when you turn hard in one direction? both?
Domindart
May 18, 2009 07:32 AM
costaricausa
Dec 19, 2008 08:43 PM
costaricausa
Dec 16, 2008 09:51 PM
bigmonk
Nov 15, 2008 07:31 AM
bigmonk
Nov 15, 2008 05:50 AM
