brake fluid leaking out bottom of resevoir
Old May 15, 2009 | 11:28 AM
Domindart's Avatar
Default brake fluid leaking out bottom of resevoir
On my 91 accord, there is brake fluid leaking out the bottom of the resevoir, where you fill the brake fluid. I have tried tightening down the resevoir, its fastened on w a clamp and flat head bolt. I dont want to overtighten though or it may brake it. Is there a seal in the bottom of the resevoir where the fill bucket sits ontop of the mastr cylinder? I wanted to know from u guys before I take it off.
Also, will I have to bleed the brakes or do any thing additional after I get this fixed? thnx everyone
Old May 15, 2009 | 05:47 PM
Domindart's Avatar
thought it was funny that there are 20,000 members and I get 8 views and no posts in 7 hours.
Guess I will inspect this myself.
Old May 15, 2009 | 05:53 PM
deserthonda's Avatar
try to tighten the 10 mm bolt clamp , , also make sure that the reservoir is all the way down,
Old May 15, 2009 | 07:23 PM
Domindart's Avatar
thnx, I cleaned it all up and put some gasket sealant on it, should be okay.
Do I have to bleed brakes or anything, or can I just refill? There was still fluid in the mast cylind top.
Old May 16, 2009 | 10:09 AM
Moppie's Avatar
No need to bleed the brakes, unless you pumped the pedal or worked the master cylinder with no fluid in the resevoir.
Old May 16, 2009 | 10:27 AM
Post
If you haven't filled it full of brake fluid, wipe out rest of fluid and get the sediment out of the bottom of it..
Old May 17, 2009 | 04:16 AM
Domindart's Avatar
well, I tried fixing it w gasket sealant and it leaked worse, so Im going to go back to step 1 and just try to tightn it down as tight as it will go aftr I get all the gasket off. If it leaks Ill b looking for a replacement cup.
I did drive it for a bit with just a bit of fluid on the brim of the mcylinder, I dont think I messed the brake systm up, but as far as clean fluid, I will flush the systm at a latr time.
I hope I just need to tightn it down more!
Old May 18, 2009 | 07:10 AM
The parts breakdown doesn't even show the reservoir as a separate part. Since it keeps leaking, I would check real carefully for cracks or something like that.
Old May 18, 2009 | 07:32 AM
Domindart's Avatar
thnx for the post, and Im finding out that the mc and the cup are one part- I cant pick up the cup at the parts store without buying thw mc.
Im going to call the honda dealer and see if I can get the cup, if not Ill have to vivist a yard like pull a part.
I found a crack in the cup . I dont know if it was always there or if it happened when I was tightning it down but oh well.
nyaccodguy
Mar 17, 2015 06:38 PM
AccordNation
Jan 7, 2009 11:14 AM
maro
Feb 4, 2008 06:20 PM
Skeete32
Mar 13, 2006 02:09 PM
