Power window plz help (raining)
Old Jun 20, 2006 | 08:47 PM
sir_nasty's Avatar
Default RE: Power window plz help (raining)
if you want your window up I'd pull off the door panel and unbolt the window then cut a piece of wood to length and stick it inside the door and wedge it in there so it holds the window in place in the up postion. Then zip tie the board in place so it doesn't slide out...
Old Jun 20, 2006 | 10:58 PM
lightshow's Avatar
dam thats gangster
Old Jun 20, 2006 | 11:08 PM
cenkaetaya's Avatar
ya the prob with that is that its like 85 degrees outside during the day. Its also been raining quite a bit here lateley in new england. So its like...rain,......rain....hottness
its really annoying.
Old Jun 21, 2006 | 04:47 AM
deserthonda's Avatar
A couple pf things..........
# 1 , i am sorry for your present dilemma but let keep the vocabulary clean..........
# 2 ,, have you checked the fuse ??? .. chk fuse # 28,, 20 amps , in the underhood fuse box
if the fuse is ok.. you need to chk to see if you are getting powr at motor, ,, remove door panel , get a test lite, hook 1 side to a god ground source , when you push the main window switch to up, you should get power at red/yellow wire ..........when you push switch to down, it should be at red/blue wire......
if you get those than you got a bad motor,,
If no power , you could have a dirty switch, i have seen it many times, contacts on the switch get dirty and pitted..
try this and post results//////// and again Please keep the vocabulary clean.................Thanks ..
Old Jun 21, 2006 | 12:10 PM
cenkaetaya's Avatar
one more qestion
Lateley the radio stations constantly get reset as if the car ran out of battery. Could this have anything to do with it? Becase it didnt used to happen before.
o ya sorry for the horribly foul language.
Old Jun 21, 2006 | 12:36 PM
incountry's Avatar
does the car have a alarm system on it
Old Jun 21, 2006 | 02:02 PM
  #17
sir_nasty's Avatar
if they hooked up the stereo (aftermarket?) to the fusebox/fuse that the door runs on (seen it done on occasion but a bit odd...) then it would make perfect sense. If that fuse blew then it would cut your constant memory power and kill your door window too.... while you're looking at the fuses you might as well just go through them and make sure nothing else is blown...
Old Jun 21, 2006 | 02:49 PM
  #18
cenkaetaya's Avatar
i just noticed that when i push the window down can hear the motor working a bit.
This probably means my chances of getting it to work by just fixing some wires are pretty good right?
im gona take it appart later today and have a look.
Old Jun 21, 2006 | 05:24 PM
  #19
sir_nasty's Avatar
if you can hear it working a bit then it's either wires or a regulator....
Old Jul 4, 2006 | 01:53 PM
  #20
cenkaetaya's Avatar
amazingly enough
after over two weeks of being a slacker and not doing **** about my window it started working by itself.
ahh im so happy that i didnt spend any money on this and was a lazy bastard
jkeely
May 2, 2012 03:48 PM
Opballer
Feb 9, 2012 11:54 PM
EBK142
Apr 27, 2010 03:31 PM
90accord90
Jan 16, 2010 06:01 PM
mmazb3
Nov 26, 2007 03:16 PM
