Power window problems
Old Jun 24, 2008 | 01:25 PM
drew and not u
Default Power window problems
Hi everyone. I purchased a 2003 2-door Accord EX V6 a month or two ago and I've been having problems with the driver side power window. The window switch always felt a bit loose, and shortly after I got the car home the switch would stop working intermittently. Every couple of days it would not roll down when I pressed the switch, sometimes fiddling with it would make it work, sometimes I just had to wait a few minutes, and it would start working again. And it was only rolling it down I had a problem with, it would always roll up.
The other day I had the windows down and the driver-side window refused to roll back up. Checked the fuses and they were all fine. I figured it was just the switch. I took the panel apart at home and ended up breaking the switch all the way off (it was apparently already half broken).
So I went to the dealership and coughed up the $175 for a new power switch. The part came in this morning and it did not fix it (but I need it anyway since the old switch is broken). The passenger window still works fine, but I cannot get the drivers side to come up. I'm going to take the door panel off tonight and see if I can see a loose connection or something. Anything specified I should be looking for?
And just today at lunch the passenger window stopped working. Is there another control unit or something for the windows that I could look at?
Also, with the new control unit plugged in my keyless entry doesn't work. Do I need to program it somehow or what? I really appreciate any help you guys can provide as this has been a giant pain having my windows stuck down (thunderstorms all week).
camcyddev
Sep 26, 2013 05:09 PM
jkeely
May 2, 2012 03:48 PM
Opballer
Feb 9, 2012 11:54 PM
BlackGoose
Jun 11, 2008 07:35 PM
mmazb3
Nov 26, 2007 03:16 PM
