Power Window Problems on 2003 Accord
Old Feb 23, 2012 | 04:05 PM
tmags2's Avatar
Thank you. I ordered the part today. I'll let you know what happens.
Old Feb 28, 2012 | 06:39 PM
tmags2's Avatar
Ok, the new regulator is in and works great - almost.
Let me try to explain what is happening. I tested the window using the passenger button - works great. Drove the car and tried to put the window down from the drivers side - nothing but a click. When I tried the passenger side again - window went down as long as I was holding the button - as soon as I released the button the window reversed and went back up. Continued to happen while using the passenger button.
Next I pushed the drivers button again - only heard a click, but this time when I hit the passenger button it went down and stayed down.
But wait - I was able to raise the passenger window using the driver side button - along with hearing that click again.
Now when I hit the passenger window it repeated what happened in the above step - up/down and the driver button does nothing again.
Short or what?
Old Feb 28, 2012 | 06:46 PM
You probably have to reset the power window system. See my post in this thread:
https://www.hondaaccordforum.com/for...problem-35506/
Old Feb 28, 2012 | 07:25 PM
tmags2's Avatar
I just tried to reset the power window system and it did not work. I held the button long enough where I heard it reset.
As I tested the button on the drivers side that controls the passenger window I heard what sounded more like a solenoid sound rather than a click coming from the passenger side.
Old Feb 28, 2012 | 07:34 PM
Try this other reset procedure.
2003 Accord window issue - Honda-Tech
Let me know if this works.
I hope it does not turn out to be a problem with the multiplexer. I can post a link for info. on that too.
Old Mar 3, 2012 | 07:13 AM
tmags2's Avatar
I connected the two battery cables together and still nothing. Maybe it is the multiplexer as you stated above. I don't know what that is. Is it a hard fix and is it expensive?
Thanks
Old Mar 10, 2012 | 06:01 AM
  #17
i4getlots's Avatar
Default 07 accord with same problem...
i have an a 2007 accord ex with the same problem. however the only window that works is the driver side window. none of the switches work from the driver side or at each window individually. i really don't want to have to replace 3 motors!!
Old Mar 10, 2012 | 09:15 AM
  #18
tmags2 and i4getlots,
See this thread and read Justinsbg's posts regarding diagnosing the driver's side multiplexer:
2007 Accord window problem - Honda-Tech
Old Mar 12, 2012 | 06:41 AM
  #19
i4getlots's Avatar
thanks that is very helpful!!
however should i try to reset the windows before i try diagnosing the multiplexer? seems like a good idea?
Old Apr 1, 2012 | 11:06 AM
  #20
adventureone's Avatar
Default replacing window motor regulator
I am attempting to install a new window motor / regulator: where do I find directions on how to perform this replacment.
Jeff247
Jun 14, 2012 07:18 PM
jkeely
May 2, 2012 03:48 PM
Opballer
Feb 9, 2012 11:54 PM
Jeff247
Apr 27, 2008 03:04 PM
mmazb3
Nov 26, 2007 03:16 PM
