Power windows
Old Nov 1, 2008 | 03:20 PM
Hondanovice
Default Power windows
92 Honda Accord LX, 4 door, 4 cylinder, auto trans, power windows work both the switch and motor but sometimes don't go up all the way. I have to have my wife hold the switch while I pull the window up with the palms opf my hands. only the passenger side front and back have this problem the drivers side is OK. Also unrelated, but the power Antenna does not go down any more even though I can hear the antenna motor trying to power it up or down. I thought these problems might just need some liquid silicone somewhere? What do you think? I am just a novice but very practical.
[IMG]local://upfiles/18902/673F0A9A9C2B407BA7EB4BD60F44115A.jpg[/IMG]
Old Nov 1, 2008 | 04:47 PM
finch13's Avatar
Default RE: Power windows
Windows: The window tracks are likely dirty and need a good cleaning. It's best to remove the windows and clean the whole track with rubbing alcohol and use a liquid silicone or dry Teflon lube on the tracks, but if that's not possible clean what you can with the window down. If that doesn't help, the window regulator might be on it's way out.
Antenna: There is a coiled, linear gear on the antenna mast that wears down over time. It can either be replaced with a new/used antenna or what I did when it happened is I pulled the antenna all the way up and unplugged the motor.
Is that picture above of you?
Old Nov 1, 2008 | 06:31 PM
deserthonda's Avatar
most likely you will need a window regulator ........ and an antenna mast
Old Nov 3, 2008 | 01:34 PM
Hondanovice
Thank You for your suggestions, and yes that is me in the picture. I originate residential mortgage loans for a living. negotiate discount notes and accounts receivables too.
Old Nov 3, 2008 | 01:36 PM
Ah I didnt know the 4th Gens had the window problems as well. Its a big problem in my 5th Gens. Window regulators are alot of money, so I just live with it.
Old Nov 3, 2008 | 01:47 PM
ORIGINAL: live2rice
90-93 accords specially the rear windows on a 4 dr .. we have replaced a crap load of them ,, that's when it all started with the 1990 s
you can get a non-honda regulator a lot cheaper ( checker, autozone ) normally costs around $ 100-120
As for the antenna if you do not mind doing it manually, you can get a manual antenna from the dealer for about 30-40 dollars
falge
Mar 11, 2008 06:47 PM
th22ek9
Sep 13, 2006 11:11 PM
th22ek9
Sep 8, 2006 09:07 PM
smoovekriminal
Apr 22, 2006 12:28 PM
sir_nasty
Mar 15, 2006 05:31 PM
