Power Windows not working
Old Aug 14, 2012 | 08:42 PM
This sounds like fun.....
So the drivers side window works fine......but the pass side does nothing from the master switch or from the pass side switch....correct?
Old Aug 15, 2012 | 09:03 AM
chumperdink's Avatar
Default Such a JOY!!!
Poorman the Drivers side window goes up down and even has the
Auto up feature working. When I installed the new regulator and
Motor on the passenger side, I was able to roll the passenger window
up but not down. I was able to get access to a honda field service
manual, and in the power window section (22-160) I found some service
procedures. The only thing I haven't done is change the N0. 13 (7.5A)
Fuse on passenger side box. Also I did not change the NO. 14 power
window relay. Could the window still operate up with a bad relay or fuse?
Also could the window still operate up with a bad passenger window
switch. I did not change those items out because the window did
work in one direction. This really is started to drive me nuts!!!
Old Aug 15, 2012 | 08:24 PM
In the procedure, there is a test of jumping some wires (f18? to something) and the window should run, if that in the procedure/pages you have?
...ahh shoot, what year is this car, we are on page 2 and I'm too tired to go back.
Old Aug 16, 2012 | 09:13 AM
Poorman its an 01 Honda Accord 2 dr Ex. Those procedures were in the
pages. I did not do those procedures myself but the stealership said,
they were able to jump power to the window and that it worked.
Anyway sorry to drag the issue out I know it is tiring. Thanks for the help
So far. I am thinking it may be something simple that is right in
front of me. I am never touching anything electrical in this car again!!
hahahha
Old Aug 16, 2012 | 07:12 PM
There I added your info so I don't confuse myself, it will show in any posts going forward.
If F18 is jumped to battery voltage and the window goes down.....#1 issue listed is the pass side switch. After that is a broken wire or the motor......since the "dealer put power to the window" and it went down that kind of rules out the motor. In the manual I have the pic of the "F" connector to the pass side realy/fuse block is on page 22-175.
Sorry about my last post, it was late and I confused myself....someone has a 7th gen with door lock issues and you have the 6th with window issues.....I'm easy to confuse, sorry.
Old Oct 9, 2012 | 10:34 AM
Default Can't believe it!!!
Well all, I really can't believe what happened. Through all we went through
the problem is FIXED!!. Poorman sorry I took so long to get back, I pretty
much gave up on this predicament. Also, thanks to everyone for all thier help
and encouragement!! Anyway long story short, I got frustrated and took
apart everything. I was tracing the steps again from the different solutions, and
behold I started looking at the original window switch, and the one I for from
ebay. I noticed the plugs for the harness were oriented in different positions.
Turns out ebay sent me a switch for a four door rear window switch, not a 2
door ex coupe!!!! Apparently they are not interchangable. Moral of the story is
never give up never surrender, and cross your T's and dot your i's. Thanks for
all you guys's help.
Old Oct 9, 2012 | 07:13 PM
  #17
At the end of the day.....glad you figured it out. Thank you for the update.
jdenny81
Jun 2, 2012 05:28 PM
steve1962
Mar 22, 2011 08:41 AM
66StangFastback
Feb 28, 2011 08:12 AM
slithersilver
Jun 2, 2010 10:09 PM
ButtonMan
Jul 4, 2006 11:51 AM
