A problem with my headlights...
Old Oct 8, 2010 | 06:49 AM
yamban's Avatar
Originally Posted by PAhonda
Wait, so only turning on the high beams causes the fuse to blow? Just turning the headlights on keeps the fuse intact?
Exactly. As soon as the second light dial setting is selected the fuse blows (assuming thats the highbeams...in the camaro you would click the whole stick towards to wheel). If you turn the dial just once, the fuse and everything is intack... thats when I was hoping the lowbeam lights may work if I replaced them.
Old Oct 8, 2010 | 07:42 AM
Twisting the headlight switch isn't the high beams. Twist one click is parking lights, next click is low beams. Push/pull the lever is highbeams.
Old Oct 8, 2010 | 03:21 PM
yamban's Avatar
I found out whats happened... somewhere in the left wiring there's a short. Seems like the people before me couldn't find it either and purchased another headlight connector, wiring it into the right headlight wires by the battery and ran it down in front of the rad. After I repaired the shawty connecting they did and replaced the bulbs, they both work on the right 20 AMP fuse.. is this ok for the time being or are they not going to be as bright? I figure it would overload the fuse but nope...
So for all I know the highbeams work they just lack the actual bulb.
Old Oct 9, 2010 | 07:32 PM
Well, best is to fix the short in the original wires for the left headlight. But since your fix works, I guess it's OK. The fuse would be sized for the wire gauge (to avoid overheating the wires). Can you look up in the manual (maybe on the fusebox cover) whether that 20-amp fuse is the correct size for that circuit?
Pilot Mobbin
Jan 30, 2013 07:18 AM
arista blouin
Dec 5, 2011 02:01 PM
bwhillzy
Aug 28, 2008 11:48 PM
Slither1989
Apr 11, 2006 02:10 PM
Slither1989
Apr 10, 2006 08:59 PM
