Problem starting
Old Sep 14, 2011 | 05:20 PM
blkr6's Avatar
Default Problem starting
my friends 92 honda accord starter went out three months ago and it sat for all this time. today i decided to help her out and i changed the starter. after the starter installation car cranks fine but it wont start.
-so i checked the spark and it was very week and spark plug boots were soaked with oil
-loosened the fuel line where it attaches to the fuel rail it squirted out fuel
then i...
-i changed spark plug wires and plugs
-changed the valve cover gasket set
-changed the battery
now the car catches up a little with starter fluid but it dies right after. this car ran perfect before starter gave out, i dont know why this car wont start anymore. any advice will be appreciated.
Old Sep 14, 2011 | 05:38 PM
Your test with starter fluid seems to indicate a fuel problem.
Your description makes it sound like a spark problem.
In the common DIY thread on top of the gen tech help forum, open the link on how to check engine codes. Post any codes you get on here.
I would disconnect the battery and clean all ends of both battery cables with a small wire brush or sandpaper.
There is a ground bolt on the thermostat housing that you will want to disconnect and clean up as well.
Do you have a timing light?
Old Sep 14, 2011 | 08:51 PM
To add, turn the key to "on" watch the cel light-does is come on and go off after ~3 seconds?
Old Sep 15, 2011 | 12:12 PM
blkr6's Avatar
thanx guys ill check out the check engine light and i do not have a timing light.
Yamasaki
Nov 5, 2011 09:19 AM
quack31
Feb 5, 2007 05:07 AM
cyurgeles
Jan 21, 2006 10:36 AM
rev2ninetyper
Nov 14, 2005 04:06 PM
karmajay
Sep 13, 2005 06:57 PM
