problems after changing distributor o-ring and sparkplugs
Old Mar 2, 2013 | 11:56 PM
Donpop's Avatar
Default problems after changing distributor o-ring and sparkplugs
Hi all, was wondering if anyone would have any insight into this, i changed the distributor o-ring and sparkplugs on my 2000 accord ex, when i started it up the CEL came on and when i put it into reverse there was a loud clunk but it still moves, but when i put it into drive its the same as if its in neutral and it wont move. I checked the tranny fluid and its ok. Any help would be greatly appreciated
Old Mar 3, 2013 | 05:16 AM
Only suggestion is to extract code. That may provide a clue. Your maintenance items should not affect transmission, unless you accidentally damaged something.
Old Mar 3, 2013 | 03:13 PM
Did you do ANY other maintenance/repair things?
Old Mar 3, 2013 | 03:49 PM
Donpop's Avatar
Turns out i put the distrubutor on backwards and it fried the shift solenoid luckily it didnt snap the cam shaft, just gotta replace the solenoids and should be all good. Thanks for the replies.
neejay
Aug 6, 2022 02:14 PM
Frugalhondaguy
Apr 13, 2015 05:18 PM
darkgreen18290
Oct 24, 2012 09:38 AM
Shag Wagon
Oct 23, 2010 10:12 PM
Dhorn33
Jan 30, 2007 12:10 PM
