Punctured the oil filter 03 Accord EX-L
Old Dec 3, 2015 | 10:17 PM
skyfire322's Avatar
Default Punctured the oil filter 03 Accord EX-L
Hey everyone! I was doing an oil change today, and when I used the oil filter pliers to take it off, the pliers chewed the filter up so it now looks like a crushed soda can.
The filter is stuck on there real good too. I've tried PB blaster, and I also tried the screwdriver trick, but that just made things worse. I'm wondering if the best course of action would to be to drain all the oil, get it towed to the garage and have them just put it on a lift to take it off.
The problem is that I can't get a good angle because it's in such a tight spot, even when it's on the ramps.
Old Dec 3, 2015 | 11:33 PM
Prospector's Avatar
It does sound as if the car needs to go to a shop. Do you know a reliable mechanic?
Old Dec 3, 2015 | 11:53 PM
skyfire322's Avatar
I do. Luckily, the shop I go to is only a half block away so worst case scenario, I can just push it there.
Old Dec 4, 2015 | 08:58 AM
There is a spring-loaded friction grip "socket" tool to engage the oil filter housing,...if there's enough intact housing to grip.
There is also a strap wrench which wraps around and presents a square socket for a 1/2" ratchet. I've used one I have successfully on very tight filter housings. However, there is a crushing force from this type of wrench that may not work w/ a damaged filter housing.
An air impact hammer w/ chisel bit may be able to impact edge of housing base to provide loosening force. Access is key unknown.
A shop should be brought in w/ a lift to find best option before more damage. Worst case may require welding a nut to base to provide something to turn the filter base out.
Old Dec 4, 2015 | 08:42 PM
Got a long screwdriver? Hammer it through the filter then use that as a lever to get it started unscrewing.
Old Dec 5, 2015 | 05:02 PM
skyfire322's Avatar
I did try but unfortunately when I went to unscrew, it ripped the filter even more. I'll be taking it to the garage after work tomorrow night.
Just out of curiosity, should I drain all the oil before dropping it off just so they won't have an unexpected surprise having oil shoot all over the place?
Old Dec 5, 2015 | 06:06 PM
No, leave the oil in the pan.....just my opinion, don't want to chance a mistake in communication and they replace the filter and start it up to be sure there are no leaks.....and it goes bad because there is no oil in the pan.
Again, just me.
Old Dec 6, 2015 | 06:08 PM
Prospector's Avatar
I agree... do not drain the oil, though be sure to let the garage know that the crank case is still full.
May as well have the oil changed while the car is in the shop
Old Dec 7, 2015 | 10:11 AM
Dr. Drivability's Avatar
Pulling the passenger side wheel off gives you a straight shot to the filter...mangled or not you should be able to get if off...
Old Dec 8, 2015 | 02:13 PM
skyfire322's Avatar
Well, the garage was able to replace the filter. They were a little rude about it, but all is well now.
Thanks for all the replies! I'll remember this in the future.
