Question about break light
Old Oct 12, 2011 | 09:06 AM
Eggyb's Avatar
Unhappy Question about break light
I have a 1999 Honda Accord Ex. 4cylinder. Every morning when i turn on the car the break light comes and stays on for about 5 to 10 minutes, then goes off. It only happens in the morning after the car has been off for about 10 to 13 hours. After the initial start up i turn on and off the car multiple times and break light does not stay on. Please help!
Old Oct 12, 2011 | 06:44 PM
I assume this is the same light as if you had the e-barke on?
Check the fluid, then I have to ask when it was flushed last. Then inspect the "sensor" inside the cap for proper movement and readings.
Old Oct 13, 2011 | 12:37 PM
Eggyb's Avatar
Smile
yep. it is that light. and thank you i am going t check the fluids and the sensor today
Old Oct 13, 2011 | 12:57 PM
If the brake fluid level is okay, it may be the master cylinder filter and/or the float. See this Honda TSB. Copy and paste without the quotation marks ("' ") to see link.
"http://www.tegger.com/hondafaq/tsb/accord/x03-078e.pdf"
IslandAccord
Jan 9, 2011 04:35 AM
louh
Feb 13, 2008 12:06 AM
jbl2bgone
Nov 7, 2007 09:56 AM
bigheadballer
Aug 27, 2005 08:16 PM
bigheadballer
