Sponsored by:
Sponsored by:
question about noise in front end
Old 12-11-2012, 06:08 PM
sonoma's Avatar
Default question about noise in front end
I park in a parking garage.I make about 20 right hand turns before i get to my spot.After each turn i hear 3 slight nocks.It is very slight and so far haven't got the mechanics to have heard it.Does this sound like a bad strut or something else.Thank you
Old 12-11-2012, 07:30 PM
Could be worn anti-sway bar end bushings or perhaps CV axle begining to fail. Check bushings and CV axle boots for damage.
Old 12-12-2012, 04:38 PM
accordfan's Avatar
Been down THIS road.
As Texashonda says, check the drive shaft boots. Highly likely one of the outer boots (boot closest to the wheel) is torn. Grease exits boot when it tears, then lubrication is gone and joint begins to "Knock" when you make sharp turns.
CrackWilding
06-27-2012 01:39 PM
00accorddriva
01-02-2008 04:05 PM
mpanelli
12-09-2007 05:04 PM
corr04
07-25-2006 11:32 PM
amp71
08-31-2005 10:51 PM
Quick Reply: question about noise in front end
