95 honda accord ex vtec shaking at complete stop
Old Dec 11, 2012 | 01:01 AM
Cldblud's Avatar
Default 95 honda accord ex vtec shaking at complete stop
Usually when im coming to a stop it has a rough idle at about 1k for a couple seconds and then its back to its normal 750, recently it has started not going down and it takes longer and longer.. just curious what this might be or if its even an issue at all~ some other info is it has been gettiong colder here tonite it was doing it really bad and its 29 degrees outside idk if this may have something to do with it any help would be awesome thank you
Old Dec 11, 2012 | 05:45 AM
Are maintenance items; spark plugs, wires, rotor, distributor cap in good shape?
Any check engine light? If so, get the code and post for help.
Clean IACV, EGR valve, and EGR manifold may help. Sticking EGR valve could cause temporary high idle and idle miss.
Old Dec 11, 2012 | 04:49 PM
Cldblud's Avatar
transmission and engine lights are not on, but the sppedometer works whenever it wants and it seems to do it more often when the speedo isn't working
Old Dec 11, 2012 | 05:31 PM
Non-working speedometer suggests a flaky VSS, which should throw a check-engine light.
So... Does your check-engine light come on for 2 seconds when you first turn the key ON? (bulb-check)
Old Dec 11, 2012 | 06:05 PM
Cldblud's Avatar
yes it comes on for 2 seconds but goes back off
would the VSS cause the shaking though?
Old Dec 11, 2012 | 07:15 PM
Does speed control work? If yes, the VSS is working.
Old Dec 11, 2012 | 07:44 PM
Silver6gen's Avatar
Yup ^^^
Old Dec 12, 2012 | 07:34 PM
Cldblud's Avatar
the crusie control hasn't worked for the year and a half i have had the car
alphaney
Feb 12, 2022 10:14 AM
kumaresh.perumal
Apr 4, 2010 11:14 AM
Itzomi
Jan 8, 2009 03:51 PM
jose310
Dec 21, 2007 08:28 AM
badxdawgx818
Sep 4, 2007 03:36 PM
