Question on moonroof
Hey, i see that the accord 08 vg coupe comes with a moonroof. Iv been lookin on the internet but cant find the difference between a sunroof and a moonroof. some sources say no difference, some say there is some. Can someone tyell me if the moonroof on theis accord opens fully or just a bit or not at all. Thanx
Generally the difference is a sunroof is steel & a moonroof is glass. The terminology isn't always absolutely consistentso you never know.
I don't have a 2008 but I'm pretty sure it's a glass panel that slides completely open OR tilts up. Then there's a shade panel you can slide shut to block off the sunlight.
Sunroof - glass that opens and slides above the roof
Moonroof - glass that opens and slides in between the roof panels.
90% of cars these days have a moonroof instead of a sunroof. I think the Scion tC still has a sunroof.
A few of my former cars illustrate...
Terminology in bold comes from the respective manufacturer's literature.
1974 BMW steel sunroof slides under the roofto open.
1986 Jetta steel sunroof slides under the roofto open.
1995 Integra glass moonroof tips UP & slides back above the roof.
1998 Accord glass moonroof slides under to open, also tilts up.
2001 Saab glass moonroof slides under to open, also tilts up.
2005 Saab glass moonroof slides under to open, also tilts up.
*Steps gingerly down off soapbox*
Now then: cars.com agrees with JimBlake. It says:
A sunroof is typically a solid body-colored panel that can manually tilt up or be removed. A sunroof is an opaque metal panel, and you can’t see through it. From the outside, it looks like a body-colored metal panel.
A moonroof is a type of sunroof, except that it’s a transparent, sliding, tinted glass panel. This panel is not removable.
Other websites seem to concur.
So the shortest possible answer...would probably be a caveman's:
SUNROOF METAL. MOONROOF GLASS.
