Quick question
Old Oct 10, 2008 | 12:11 PM
jamrock's Avatar
Default Quick question
i have a 94 ex does anyone know if the relay under the dash marked mitsuba relay ***'y main would cause no spark. i know if its bad it will cause the car now to start but min clicks constantly and goes away if i disconnect the vtec solenoind
Old Oct 10, 2008 | 02:23 PM
Default RE: Quick question
The mitsuba relay should only supply power to the fuel pump. Use a voltmeter to check for 12V going to the yel/blk wire on the two-pin connector going to the distributor. Also check that all of the ends of your battery cables are clean and secure.
Stopormymomwillshoot
Aug 29, 2010 06:18 PM
get'er go'in
May 4, 2010 12:33 PM
emaxxman
Mar 1, 2006 01:32 AM
thunder_x
Oct 3, 2005 12:56 PM
thunder_x
Oct 3, 2005 12:35 PM
