Radiator fans run constantly
Recently removed and reinstalled the motor and now the fans run as soon as the key is turned on. I have removed the connector to the temp sensor on the thermastat and the fans continue to run. What could have caused this by simply removing the engine?
I'll assume this is a 4cyl, forgot to ask that.
Is the ac off?
If so follow the green wire from the fan connector and make sure it is not "grounded" going to the relays. It might have been "pinched" during the install of the motor. Or you can test for ground on the pin of the relays for the fans.
Is the ac off?
jamesBond007
Jan 31, 2011 09:03 PM
