Radiator fans run constantly
Old May 11, 2013 | 12:29 PM
glennwood55cameo's Avatar
Default Radiator fans run constantly
Recently removed and reinstalled the motor and now the fans run as soon as the key is turned on. I have removed the connector to the temp sensor on the thermastat and the fans continue to run. What could have caused this by simply removing the engine?
Old May 11, 2013 | 12:45 PM
First, what year is this Accord?
Can we assume both fans run as soon as key is "on"?
Old May 12, 2013 | 06:46 AM
Sorry, it's a 2000 Accord and yes, both fans run when the key is turned on............
Old May 12, 2013 | 08:35 AM
I'll assume this is a 4cyl, forgot to ask that.
Is the ac off?
If so follow the green wire from the fan connector and make sure it is not "grounded" going to the relays. It might have been "pinched" during the install of the motor. Or you can test for ground on the pin of the relays for the fans.
Old May 12, 2013 | 10:31 AM
Yes it's a 4 cyl.. Where are the fan relays located? Seems I read here in another thread they are located at the fuse block.
Old May 12, 2013 | 10:51 AM
The relays are in the underhood fuse box.
drummer1279
Mar 29, 2011 02:59 PM
jamesBond007
Jan 31, 2011 09:03 PM
nitrousnick
Jul 5, 2010 01:55 PM
kornbln
Aug 30, 2008 02:16 PM
horgad
Dec 10, 2006 07:57 PM
