radiator hose too tight
Old Mar 15, 2010 | 09:17 AM
accordlxman's Avatar
Default radiator hose too tight
So i found a radiator leak yesterday!!!!
When the car is cold and i turn it on the bottom hose on the radiator manages to get really tight and leak right the through the clamp.
the top hose gets semi tight and hot
but the bottom hose stays cool until after i drive it around.
then they both get nice a loose and hot
how can i fix this problem?
the car is a 99 accord. f23 Vtec
Old Mar 15, 2010 | 10:54 AM
If it leaks at the clamp, you need to take off the hose & clean the crud from the nozzle where the hose fits. After that it would be kinda silly to put the OLD hose back on.
Try a new clamp too; yours may have lost some of it's spring tension with age??
Old Mar 16, 2010 | 03:20 AM
Default ok
so pretty much try new hoses and clamps? Are the clamps with flathead screws good for this type of job?
Old Mar 16, 2010 | 07:01 AM
Screw-type hose clamps are OK if you periodically check & tighten them. (Look for the more expensive type with depressions NOT HOLES to engage the worm-screw.) The rubber in the hose relaxes & shifts over time, so it'll loosen up after a year or 2. The spring-type clamp keeps tight as the rubber moves.
Old Mar 16, 2010 | 11:17 AM
Default thermostat?
which is better fail safe or duralast both are 170F
Old Mar 16, 2010 | 11:41 AM
Much of a price difference for a dealer thermostat???
Old Mar 17, 2010 | 09:57 AM
Default ?
how much is it at the dealer?
nitika
Aug 31, 2010 12:11 AM
accordlxman
Mar 9, 2010 10:52 AM
jamesejam
Sep 21, 2009 02:37 PM
canjoh
Feb 15, 2008 11:51 PM
sir_nasty
Sep 25, 2007 08:22 PM
