Radiator Movement
Old Jan 10, 2007 | 01:04 PM
Spatula
Default Radiator Movement
Another question fellas. I recently got my car back from the body shop after a nasty hydroplanning incident (see pics), and I was checking out the engine compartment and noticed a good amount of give in the radiator....My question, is this normal?
Thanks again!
John
Old Jan 10, 2007 | 01:52 PM
sir_nasty's Avatar
Default RE: Radiator Movement
From hydroplanning? That's not good.... The radiator is going to have a little bit of give/play to it since it is "held" pretty loosely. However, if if it's excessive you might be missing a few clips that are supposed to be on there. What year/model is it?
Old Jan 10, 2007 | 10:13 PM
hondadude's Avatar
There are brackets with rubber bushings on the top and the bottom has rubber bushings that set in 'ears' on the front subframe.
It is normal to be able to wiggle the top of the radiator in the top bushings, probably about 3/8 inch.
Old Jan 11, 2007 | 09:35 AM
Spatula
Ok, I'm good then. Thanks for the response, I appreciate it.
John
jerzeykidd
Mar 21, 2013 09:15 AM
hmr
Mar 28, 2012 10:49 PM
geode
Nov 15, 2007 08:10 PM
mck52689
Aug 19, 2007 12:19 AM
papaspe
Aug 1, 2007 10:56 PM
