Help - Shift from P to R or D and no movement
Old Jul 30, 2007 | 12:00 PM
papaspe
Default Help - Shift from P to R or D and no movement
Have a 95 4dr Accord - 4 cyl automatic - 170K
Starts up no problem, shift from P to R or Dand feel transmission engage but there is no movement. Think it's the driveshaft, as there doesn't seem to be a problem with brakes, trans fluid or any other quick diagnoses...has anyone heard or no what this problem could be? Any help would be appreciated!
Old Jul 30, 2007 | 12:28 PM
mck52689's Avatar
Default RE: Help - Shift from P to R or D and no movement
Or your tranny just might be going
Old Jul 30, 2007 | 04:16 PM
superballz00's Avatar
Almost A Senior Member
does D3 2 and 1 work?
Old Jul 30, 2007 | 05:20 PM
PhotoJim's Avatar
Could potentially be an issue with your CV joints too, although a transaxle problem is more likely.
Old Jul 30, 2007 | 06:40 PM
sir_nasty's Avatar
Does the engine rev when you shift it into gear and hit the gas a little? Inspect your drive shafts and see if they are moving or if they have come out/loose a little bit, does the dash indicate the gear?
Old Jul 31, 2007 | 06:49 AM
papaspe
I have rev'd the engine and it doesn't do anything. I did see that the dash does indicate when it goes into gear. I haven't had a chance to go underneath and check the drive shafts. Any gear D, D3, D4 and R do not work, but the transmission does catch.
Old Aug 1, 2007 | 10:56 PM
harold6091's Avatar
put it on d4 and rev it and see if your speedometer goes up if it does then it might be the driveshaft or clutch if not i would be saving some money to rebuilt the trans
rydnlow1120
11
Nov 11, 2015 05:29 PM
jerzeykidd
Mar 21, 2013 09:15 AM
geode
Nov 15, 2007 08:10 PM
mck52689
Aug 19, 2007 12:19 AM
Spatula
Jan 11, 2007 09:35 AM
