Camshaft Movement
Old Jul 30, 2007 | 01:40 AM
mck52689's Avatar
Default Camshaft Movement
Now im no expert on engines because i have help alot... but i am helping my friend put his accord back together because he had to get a new head... we put the camshaft on then the rocker arms... but im not quite sure... this ? is for people who have done a head swap or timing belt..... when the rocker arms are bolted on over the camshaft f22a... is the camshaft supposed to be able to move? or is it supposed to be in snug and not able to move without force? if you get what im saying
Old Jul 30, 2007 | 09:07 AM
Default RE: Camshaft Movement
What direction of motion?
Axial - in & out along the axis of the camshaft - not good.
Radial - grab the gear & move up down & sideways - really not good.
If it was lubricated properly when assembled, it should spin without extreme force. You'll be working against the valve springs, but should be able to spin it.
Old Jul 30, 2007 | 11:38 AM
sir_nasty's Avatar
Like JimBlake said you shouldn't be able to wiggle it around or in/out but as for rotations the cam lobes should be impacting the valves properly and then the only thing that you are working against is the valve springs, if the lobes aren't hitting anything then you have some issues.
Old Jul 30, 2007 | 12:21 PM
mck52689's Avatar
ohh no like i know the lobes will strike the cam shaft.... but im just saying am i supposed to be able to spin it... or is it supposed to be firm?.... because my brother told me i shouldnt be able to but because an engine is strong it can make it spin with the power? am i wrong on this?
because i cant turn the cam gear unless i use a socket on it and use strength.... but is that right?
Old Jul 30, 2007 | 12:44 PM
BlkCurrantKord's Avatar
Sounds right, I could've move mine when I did my head swap.
Old Jul 30, 2007 | 12:45 PM
Sounds right, I couldn't move mine when I did my head swap.
Old Jul 30, 2007 | 12:47 PM
mck52689's Avatar
ORIGINAL: BlkCurrantKord
THANK YOU!
Old Jul 30, 2007 | 10:56 PM
You can spin it with some muscle. It's not real easy.
If it's installed on the engine, you have to be careful about CRANK position so the valves don't hit the pistons. Then you'd feel pretty silly about bending your valves just by messing around & spinning the cam...
Once you get over the top of the cam, the valve spring then pushes the camshaft AHEAD. Whe the engine's running, the forces even out over time. And most important when it's running there's oil pressure and the bearings & cam lobes are being lubricated.
Old Aug 18, 2007 | 12:05 PM
LinX's Avatar
Aside from timing the head, make sure you use proper torque specs so that means get a torque wrench so you know they're on snug but don't break the bolts.
Old Aug 19, 2007 | 12:19 AM
Tony1M's Avatar
ORIGINAL: JimBlake.......................................... ............
Ditto!! You have an interference engine.
jerzeykidd
Mar 21, 2013 09:15 AM
geode
Nov 15, 2007 08:10 PM
papaspe
Aug 1, 2007 10:56 PM
Spatula
Jan 11, 2007 09:35 AM
Shavel
Dec 20, 2006 02:26 AM
