Radiator replacement complications...
Old Nov 29, 2013 | 07:48 PM
gabegallear's Avatar
Default Radiator replacement complications...
I replaced the radiator in my '99 Accord EX 4cyl. (2.3L F23A1) today with a Murray radiator from O'Reilly's (don't buy, it's not a great fit). Everything went well enough, but the clamp on one of the ATF cooler lines is not holding, and as I was idling the engine and adding coolant, it started to steadily leak from the brass fitting at the bottom of the radiator.
Is the fluid coming out transmission fluid, or is it ATF cooler oil? It looks pretty dark, like oil, but the car has 156k miles on it, so it's hard to say what it is.
If it is ATF cooler oil, how do I refill it? (I bought a new hose and clamps to replace the leaking ones.)
Old Nov 29, 2013 | 08:06 PM
It is ATF. Refill your transmission fluid to the correct level after you fixed the leak.
Old Nov 30, 2013 | 06:05 AM
Make sure the hose you bought is rated for trans cooler use.....regular fuel line will not work, or a least for very long.
BigRoach
Jun 3, 2013 01:54 PM
Novaknowledgenow
May 30, 2013 08:58 PM
hmr
Mar 28, 2012 10:49 PM
oufy
Aug 19, 2006 04:05 PM
Buckeye
Jul 31, 2005 04:25 PM
