Radio display is blank
Old Mar 12, 2012 | 07:50 PM
largeguy62's Avatar
If your radio works, but you can't see anything...I bet the culprit is a blown resistor. IF you search around, you'll find many threads just like it. Honda put out some sort of bulletin awhile back, but I hear many Honda owners are frustrated by the response. Check out this tutorial:
No Display Radio Fix - Drive Accord Honda Forums
IT WORKED!!!! A very friendly retired electrical engineer at my local hardware store helped me solder. It's really not that tough to take the unit out and take it apart. I used this video to take out the unit for a 2007 Accord radio but it was exactly the same on my 03 EX v6
How to Remove Radio / CD Changer from 2007 Honda Accord for Repair. - YouTube
Old Oct 21, 2014 | 11:51 PM
Gabe Lopez's Avatar
I'm having a similar issue with my 1994 accord EX but I think my case may be a result of removing the radio system and entering the wrong code several times. I now have the correct code and am unable to input the code.
the anti theft light is still blinking so I know that there is power as well as the lighting on the radio panel.
however, the number pad does not light when the buttons are pressed and the CODE display is not showing.
I am not getting any sound and my fuse under the dash seems to be fine.
is there anything I can try before disassembling the radio again?
Old Oct 22, 2014 | 04:11 AM
Resetting radio by pulling fuse to radio. This will allow entry of code after max number of unsuccessful tries.
Woodyhfd
Apr 2, 2013 05:20 PM
hyperphase
Jul 11, 2007 02:49 PM
kabhatti
Jun 18, 2007 08:25 PM
Castor Troy
May 18, 2007 05:38 PM
tonyh210367
May 6, 2007 08:45 PM
