Rattle in front end?
Old Jun 17, 2014 | 07:36 PM
Florida_Frank's Avatar
Default Rattle in front end?
This time my problem is with my 2002 Civic EX. If that's not allowed on the Accord forum, where might I be able to find Civic help?
There is a rattle or soft knocking on the driver's side of the front end. Most pronounced when it is idling in-gear with my foot on the brake. Some related single "pops" when starting or stopping.
Everything that I can put a hand on seems tight. The belt is tight. The car has about 84,000 miles on it.
I seem to remember my '88 Accord having a rattle when the CV joints needed replacing, but I thought that noise was when it was cornering.
Any thoughts?
Old Jun 17, 2014 | 07:59 PM
For the pops when starting or stopping, is that occurring right when you press on the brake pedal?
If so, that could be the brake pedal position switch. The switch plunger doesn’t fit squarely into the switch casing. When you press the brake pedal, the plunger rubs the side of the casing and makes noise. It can be adjusted. See attached image.
Even if the pop is related to the switch plunger, the rattle/soft knocking may be something else.
Attached Thumbnails Rattle in front end?-click-pop-when-pressing-brake-pedal.jpg
Old Jun 18, 2014 | 06:53 AM
Thanks for responding! I wasn't clear on my description of the "pops". They are more like a single-event version of the rattle. Same noise, same area -- just not a continuous rattle. It's definitely coming from the driver's side of the front end / engine compartment.
Old Jun 18, 2014 | 06:46 PM
We don't mind posting Civic stuff here, but also check:
HondaCivicForum.com - Powered by vBulletin
They might have some ideas more specific to your Civic.
joj73
Apr 7, 2012 02:49 PM
rkm152
Sep 28, 2008 02:25 AM
Steve Rosen
Jun 5, 2008 09:56 AM
dmullen
Mar 12, 2008 10:55 PM
fazzer
Feb 11, 2008 06:18 PM
